Limited Slip Differential
LSDs were fitted as standard to the 325i Sport and M3. They were not standard on the 318iS, but were on option available to all.
Case sizes
Ratios
* 3.15 - M3 * 3.64 - prefacelft 325i * 3.73 - facelift 325i * 3.91 - facelift 325i touring, cabrio, 325i with getrag 260 sport * 4.10 - found optionally on UK spec 318i/318iS 2/4dr in Small Case, and on all US M3 models in Medium Case. * 4.27 - * 4.44 -
Identification
To identify an LSD one can first check for the presence of the tag on the rear casing. The ratio on this will be prefixed with an S for LSDs.
Oil
