320i
Revision as of 21:09, 24 March 2013 by Grrrmachine (talk | contribs)
320i
320i SE
Technical
The 320i was powered by the M20B20, a 1990cc (2.0L), 6 cylinder engine and the smallest in the M20 family, below those found in the 323i, 325e and 325i. Because of its age, the engine was fitted with both Jetronic and Motronic engine management systems during its lifetime, meaning there are a multitude of differences between a 1983 and a 1994 engine, which means very few parts are interchangeable between pre- and facelift models.
However, it shares the same larger 51mm struts and vented front discs as those models, while Touring and Cabriolet models will have rear discs as well.
The 320i is commonly fitted with a 5-speed manual gearbox or an automatic gearbox. These engines are known to produce 135BHP-139BHP from the factory.
  1. Consider fitting a Chip.
  2. Fit a 325i throttle body with 320i modified inlet manifold to keep a reasonable low torque. Don't fit a 325i manifold unless you want all top end power and no pull low down.
  3. Z3 Short shifter conversion
General Info
