Engine Swap - M42
If you want more poke from your 318i without the drinking problems inherent of the bigger engines, then look no further than the M42 engine. This fizzy little four-banger features the same 1.8 litre displacement as the other E30 engines, but with double the valves (16 in all) to crank the power up to 140bhp. Combined with a simple drop-in swap procedure and easy-to-find spares from the E36, the M42 swap is a great way to liven up the smaller-engined E30 models.
Identification
M44 crank sensor location:
M42 crank sensor location:
Parts List
You need:
- M42 engine
- E30 M42 engine loom and ECU (will work with E36 engines also, saves having to adapt E36 looms and causing issues!)
- E30 M40 or M42 engine mounts
- Coil packs and HT leads or COP conversion
- M42 exhaust manifold
- 318iS exhaust system
- M42 coolant hoses
- M42 AFM to TB boot
- Getrag 240 gearbox
- 318iS propshaft
- E30-specific oil sump from an M40 or M42 engine. An M10 sump will not fit.
- Radiator upper and lower mounts are different and need to be made, designed
- Engine subframe/Mounts are about 10mm too wide for 'is' engine legs
- Coil pack needs to have a mount made and attached to hold in place
- M42 engine requires a fuel pump in the tank, or in-line AND a fuel return pipe to be added. Only way to return fuel to tank is through the filler neck breather by sender unit
- Air filter needs a bracket / Mount made
- Wiring loom requires a swap (2 wires, oil and temp need swapping) and there is a LIVE off the engine loom the goes directly into and EARTH on the multi plug! (I have it unused on my car the M10 loom and M42, possible fuel pump ign live though)
- M40 or M42 instrument cluster. This is down to an issue with the temperature gauge.
The wiring loom does cater for an in-tank fuel pump but on my car I have separate wiring to act as an immobiliser, therefore that's why my return pipe is 't'pieced back through the filler neck breather
I am also having discrepancies with the clutch slave, as sometimes it feels it wont open the clutch fully
Coil packs
Single mass:
Ancillaries
