320i
320i
320i SE
At some point during the E30 production, BMW introduced a trim level known as SE, for Special Equipment, which was only offered to 6-cylinder models (For the 316 and 318, this trim level was called LUX). This SE package makes the 320i SE a genuine BMW model, which should be shown on the vehicle registration document. The SE trim level was available on all four body styles - 2-door, 4-door, Touring and Cabriolet.
Most importantly, SE cars were entitled to optional extras from the Motorsport list, thus offering LSD, Sports Gearbox and Suspension options to the vehicle, as well as Motorsport body kits. This meant that a 320i SE could be equipped to an extremely high level, far beyond that available to a standard 320i.
Technical
Engine
The 320i was powered by the M20B20, a 1990cc (2.0L), 6 cylinder engine and the smallest in the M20 family. Larger M20 engines could be found in the 325i and 323i. The 320i is commonly fitted with a 5-speed manual gearbox or an automatic gearbox. These engines are known to produce 135BHP-139BHP from the factory.
Check the earth connectors on the suspension turret and under the inlet manifold
1) Fit a mild chip from Speedtouch or Ant (reputable E30 Zone traders). I would recommend Speedtouch at £30.00. but Ant does a fine product and gives great service.
2) Fit a 325i throttle body with 320i modified inlet manifold to keep a reasonable low torque. Don't fit a 325i manifold unless you want all top end power and no pull low down.
3) If you must fit a cone filter - build a heat shield. However the best solution is a standard filter box with a good free flow panel filter (Pipercross or K & N) then drill your front grill in line with the air pick up pipe. 10mm holes are fine just where the bottom of the grill fins are blanked off (you will understand when you look at the grill)
2) Fit a good lowering kit such as Koni but only with a 30 or 40mm drop.
3) Fit an anti-roll bar to the back ( not all 320's had them ) But do make sure you get the brackets that fit on the rear arms.
4) New front control arms are nice if you can afford them or a MUST if the joints are worn.
5) The ride will now be harsh, to smooth it out fit Sparco solid strut braces front and rear.
6) Wheels and tires of your choice, but make them at least 15”x 7”.
Braking
1) Fit Stainess Steel braided hoses.
2) Fit new discs, (You don’t need drilled on a 320i.) B.M.W. are best.
Various
1) Z3 Short shifter conversion
2) Clutch stop (look in the U.S. web sites for details) if you fit both of these modifications it 'aint half a lot more fun to drive
General Info
