Instruments
Dash Cluster
SI Batteries
Coding Plug
Individual Gauges
Speedometer
Odometer
Fuel Gauge
Temp Gauge
Tachometer
Econometer
Dash Lights
Battery Light
Oil Pressure Light
Check Light
Brake Lights
Indicators
Main article: Indicators
Inspection Lights
The LED light bar is your Oil change indicator, and is made up of five green, one yellow and one red. Up to five green LED's will light when the ignition is turned on. However, the LED's will extinguish once the engine is started, counting down to when your oil change is due. When the yellow light comes on, it's time to change the oil. When the Red light comes on, this means that service is overdue by approximately 1000 miles. Once the service has been completed, the service lights should be reset. The system is not intelligent; again, it works purely on a timer and has no knowledge about whether you've actually changed the oil or not.
OBC
Main article: OBC
Check Panel
- Coolant Level
- Oil Level
- Windscreen Washer Level
- Front Lights (Dipped Beam)
- Rear Lights
- Numberplate Lights
- Brake Lights
Extra Gauges
VDO Gauges
Alpina
