325i
Revision as of 20:27, 9 February 2012 by Grrrmachine (talk | contribs)
325i
325i
Being a "standard" E30 model base, the E30 325i was available as a coupe, saloon, Cabriolet and in later years as a Touring. Like all models (apart from the "Touring" model), the 325i was available during the "Pre-Facelift" era (known for its chrome bumpers and other touches) and the "Facelift" era (Plastic bumpers).
The 325i is considered the most sought-after standard E30 due to its desirable engine and availability over other models. There are "rarer" models (such as M3 and tuner model cars) but these are serious collectors' items with a price to match. Commonly, people choose the 325i as the E30 of choice.
During its production run, the 325i was available in all four E30 body types, at the following times:
325i SE
At some point during the E30 production, BMW introduced a trim level known as SE, for Special Equipment, which was only offered to 6-cylinder models (For the 316 and 318, this trim level was called LUX). This SE package makes the 325i SE a genuine BMW model, which should be shown on the vehicle registration document. The SE trim level was available on all four body styles - 2-door, 4-door, Touring and Cabriolet.
Most importantly, SE cars were entitled to optional extras from the Motorsport list, thus offering LSD, Sports Gearbox and Suspension options to the vehicle, as well as Motorsport body kits. This meant that a 325i SE could be equipped to an extremely high level, far beyond that available to a standard 325i.
325i Sport
Main article: 325i Sport
325i
As the SE package became increasingly popular, UK dealers planned a new package would equip a standard 325i with the full SE trim level and the best Motorsport items as standard, but only mounted to 2-door bodies. This car would be known as the 325i Sport, and is a UK-only model.
All cars were fitted with LSD as standard, as well as M-Technic bodykits. However, the only way to differentiate a fully-equipped 2-door SE with a standard Sport is the black headlining fitted to the roof of the car.
There where two models of this car commonly referred to as a "Tech-1" and a "Tech-2". The 'Tech-1' refers to the pre-facelift model and 'Tech-2' refers to the facelift model.
Classic options were the sport gearbox (or automatic sportbox). Also they had the sports interior, which could be fitted with optional materials, including the 'Houndstooth' cotton or a range of leather interiors. Other optional extras were available to the buyers of Sports that weren't available to buyers interested in the "standard" 325i.
The 325i has also been used as the base for the Alpina C2.7 series of E30s, as well as those of other tuning companies.
Technical
Engine
Main article: M20
The 325i was powered by the M20#M20B25, a 2495cc (2.5L), 6 cylinder engine and the largest in the M20 family. Smaller M20 engines could be found in the 320i and 323i. The 325i is commonly fitted with a 5-speed manual gearbox or an automatic gearbox. These engines are known to produce 165BHP-175BHP from the factory.
Main article: Suspension
The 325i had a different suspension setup to the other models (other than the cabriolet and later touring models). The 325i was fitted with 51mm struts as standard, compared to other coupes/saloons which where fitted with 45mm struts. The 325i was also fitted with rear disk brakes (as opposed to drum brakes).
Differentials
Main article: Differentials
Options
General Info
Weight balance = % front / % rear
Unmanned weight = kg / lbs
Power to weight ratio = 6 bhp/ton
Wheel base = 101.2"
Base price when new = std £ (1990)
Please also see the E30 325 Register
