Bushes
Revision as of 22:40, 3 March 2012 by Grrrmachine (talk | contribs)
(Originally Submitted on the E30 Zone by OBs)
Heres a list of what you might need. The M3 options do fit normal road going E30's, it is for the non 'M' car that I have put this list together.
The Wiki has guides to removing and replacing many of these bushes. To learn more, just click on the name of that bush.
Front
- Pair of E30 M3 eccentric top strut mounts (31331139484) - £94.41 each
- Studs x6 (31331092886) - £3.56 for 6
- Nuts x6 (31331092887) - £0.95 for 6
- Pair of E30 M3 eccentric lollipop bushes (31129061222) - £85 pair
- Drop Links (31351091764) - £54.03 pair
Superflex sell a set of replacement bushes @ circa £20
- Pair of front ARB bushes - £18.55 pair
- 18mm - (31351127414)
- 20mm - (31351129139)
- 21mm (Cab) - (31351132355)
- ARB & Drop Link fasteners £5 extra per link
- Nuts (07119922856) & Bolts (07119901120) to suit the ARB mounts
- Nuts (07129964672) Washers (31111114348) to suit the Drop links
- N/S Track control arm (31121127725) - £92.81
- O/S Track control arm (31121127726) - £92.81
Rear
- Pair of E46 M3 Cab top shock mounts (33526779670) - £33.30 pair
- Pair of E30 rear beam bushes (33311129144) - £52.39 pair
- Set of Trailing arm bushes (33329061945) - £12.88 per side
or
- Eccentric Trailing arm bushes (33329058822) - £16.12 per side
- Pair of ARB bushes £5.68 pair
- 12mm (33551129677)
- 13.5mm (33551131290)
- 14.5mm (33551130349)
- Pair of ARB drop links (33551126932) - £23.50 pair
- ARB & Drop Link Fasteners Extra £8 per side
- Nuts (07129946400) & Bolts (07119912501) to suit the Drop links
- Nuts (07129900047) & Bolts (33321136406) to suit the Trailing arm
- Bolt with washer (07119915066) to suit the ARB mounts
- 3.0 / ZM3 Differential mounting bush (33172228425) - £21.34
