Anti-Roll Bar
Revision as of 16:56, 4 February 2012 by Grrrmachine (talk | contribs) (New page: The Anti-Roll Bar or '''ARB''' is an integral part of your car's suspension. Its function is to reduce body roll by locking together all the suspension components across eac...)
The Anti-Roll Bar or ARB is an integral part of your car's suspension. Its function is to reduce body roll by locking together all the suspension components across each axle. By stiffening the entire system in this way, it's possible to dramatically reduce the wallowing, lurching motion that is often encountered otherwise.
A number of sizes of ARB were fitted to the E30, and upgrades were available from a number of manufacturers including AC Schnitzer and Racing Dynamics. The thicker the ARB, the stiffer the suspension. See the tables below to see what was fitted to your vehicle.
Standard
BMW offered an impressive range of ARBs, designed to combat the suspension niggles specific to each body style and and engine. While Front anti-roll bars were a standard feature, not every car received a rear ARB.
BMW Anti-Roll Bars
Model Front Rear
17mm 18mm 19mm 20mm 21mm 12mm 13.5mm 14.5mm
318i x
318iS x x
320i
325i x x
325i Sport x x
325i Convertible x x
325iX x x
325iX Touring x x
M3 x x
M-Technik x x
WARNING: This list is NOT comprehensive! We have not yet ascertained whether all Tourings and Cabriolets had the same suspension. If you are unsure as to the size of your ARB, try to fit a spanner onto the bar itself. For example, if you can fit a 14mm but not a 13mm spanner around your rear ARB, then it is 13.5mm.
Aftermarket
While BMW offered an impressive range of ARBs for the E30, many were simply not beefy enough for true performance driving. Because of this, a number of tuners offered much stronger versions as bolt-on upgrades.
Aftermarket Anti-Roll Bars
Manufacturer Model Front Rear
AC Schnitzer 20mm 16mm
Eibach 20mm 16mm
H&R Adjustable 22mm 18mm
Ireland Engineering 22mm 19mm
Adjustable 25mm 22mm
Racing Dynamics Early Style (adjustable) 22mm 16mm
Late Style (adjustable) 22mm 19mm
Suspension Techniques 22mm 19mm
Whiteline 24mm 16mm
