Lights
While it's often joked that these things don't exist on BMWs, the E30 is equipped with a variety of Lights to help you and other road users
Headlights
Dipped
Bulb: H1 55W
High Beam
Bulb: H1 55W
Parking
Bulb: 12V 5W capless
Headlight Washers
Headlamp Adjusters
Rear
Two types of rear cluster were fitted during the lifetime of the E30, with the change being part of the 1988 facelift. For this reason, not all rear clusters are interchangeable, although clusters from all body styles of the same year can be swapped over.
Rear Lights
Bulb: 12V 10W
Brake Lights
Bulb:12V 21W
If your brake lights are on constantly, look at this switch before you go hunting around in the Loom for bad connections. Sometimes the switch works loose from its housing, and just needs to be clipped back into place.
Reverse
Bulb: 12V 21W
- Pull the gearlever gaiter up from the bottom and fish out the white two pin connector from near the bottom of the gearlever.
- Short the two pins together with a piece of wire, and the reverse lights should come on with the ignition switch. If they do, the fault is with the switch.
- If they don't, look elsewhere. Check the fuse first, then the light clusters.
Licence Plate
Bulb: 12V 5W Festoon
Indicators
Bulb: 12V 21W
The orange bits at each corner of your car are there to signal your intentions to other road users. They are called Indicators, and are controlled by a column stalk switch. In typical fashion, if a bulb blows then the indicator on that side will flash twice as fast as before.
These lights also form part of the hazards circuit, and therefore all the wires go through the Hazard light switch on their way to the lamps. If all of your indicators stop working, then check that switch, and ensure that it is plugged in correctly.
Side Repeaters
Hazards
Foglights
Essential for driving in gloomy conditions, a clean set of foglights compliments the front end of the E30 perfectly, which is why all cars are capable of fitting them. They will only work if the headlights are already turned on.
Front Fogs
Bulb: H3 12V 55W
Rear Fogs
Bulb: 12V 21W
Just like the fronts, Rear Fogs were an optional extra. Unlike the fronts, they don't do anything to light up the road; they're there to stop people ploughing into the back of you on misty, gloomy roads. They shine with the same brightness as brake lights, so shouldn't be used during good-weather conditions.
Wiring for the rear fog lights is built into the loom, so shouldn't need to be touched; however, the wires are coloured yellow/black and grey/violet if you need them. Unfortunately, you can't just plug in a bulb and make the rear fogs work; the bulb holder panel will be missing a crucial conduit and will need to be replaced with a fog-friendly version, unless you're handy with a soldering iron.
If you think you need rear fog lights, learn more about retrofitting rear fog lights.
Interior
Mirror Light
Instruments
Bulb: 12V 3W baseless (cluster) 12V 1.2W baseless (heater controls)
Some basic candles are fitted to all E30s to help you read your Instruments at night. These lights will glow as soon as the Lights#Headlights are turned on, and their brightness can be controlled by turning the headlight knob clockwise or anti-clockwise.
Glove Box
Bulb:
HIDs
Tinting
Smoked Headlights
Tinted Rears
