Instruments
Revision as of 14:33, 16 December 2011 by Grrrmachine (talk | contribs)
Dash Cluster
SI Batteries
Coding Plug
Individual Gauges
Speedometer
Odometer
Fuel Gauge
Temp Gauge
Tachometer
Econometer
Dash Lights
Oil Pressure Light
Check Light
Brake Lights
Indicators
Main article: Indicators
Inspection Lights
OBC
Main article: OBC
Check Panel
  • Coolant Level
  • Oil Level
  • Windscreen Washer Level
  • Front Lights (Dipped Beam)
  • Rear Lights
  • Numperplate Lights
  • Brake Lights
Extra Gauges
VDO Gauges
Alpina
Alpina digital gauges
