Plate
Master Cylinder
Slave Cylinder
Gearbox ratios are also dependent on the ratio of your diff. For example, a high ratio diff (4.27) combined with a high-ratio first gear (3.72) will make first gear useless. In contrast, a low-ratio diff (3.25) with a low-ratio gearbox (2.48 in first)
The E30 was available as both a Manual and an Automatic. In total, seven different gearboxes were fitted to the E30; Four manuals, all produced by Getrag, and three automatics by ZF.
Manual
| 1st | 3.76 | 3.72 | 3.72 | 3.76 | 3.83 | 3.72 |
| 2nd | 2.04 | 2.02 | 2.02 | 2.33 | 2.20 | 2.02 |
| 3rd | 1.32 | 1.32 | 1.61 | 1.32 | 1.40 | 1.32 |
| 5th | 0.81 | 0.80 | 1.00 | 0.81 | 0.80 | |
| Reverse | 4.10 | 3.45 | 3.71 | 4.10 | 3.46 | 3.46 |
The M42 engine mates up to the same gearbox used in M40 engines, but is not campatible with earlier M10 gearboxes due to the angle of installation, which will cause problems with the shifter and rear gearbox mount. In a similar way, although the M40 and M42 boxes are interchangeable, the input/output shafts are different and so is the propshaft. This means that replacing a 318iS gearbox with the more mundane 318i unit will necessitate a change in prop.
- Getrag 240 - MN or BMV
 - Getrag 242 - LF, MD or BMU
 - Getrag 242/5 - AY, AW or LG
 - Getrag 245 - BJ
 - Getrag 260 - NW, ANB or TNW
 - Getrag 260/5 - TNN or HM
Automatic
| 1st | 2.48 | 2.73 | 2.48 |
| 2nd | 1.48 | 1.56 | 1.48 |
| 3rd | 1.00 | 1.00 | 1.00 |
| 4th | 0.73 | 0.73 | |
Selector
Propshaft
Guibo
Bearing
Main article: Differentials
Output Flanges
Drive Shafts
