Revision as of 08:28, 29 October 2011 by Grrrmachine (talk | contribs)
Brake Pedal
Brake Light Switch
Brake Servo
Intake Valve
Master Cylinder
Reservoir
Pressure Valve
Brake Fluid
Main article: Brake Fluid
Brake Lines
Brake Hoses
Calipers
Discs
Pads
Pad Wear Sensor
Drums
Cylinders
Shoes
Handbrake
Rear disc handbrake setup
ABS
Main article: ABS
Bleeding
  2. Unscrew one quarter turn
  4. Retighten bleed screw
Replacing Pads and Discs
For REAR discs:
Replacing Fluid
Replacing Rear Shoes
Then adjust the handbrake.
Adjusting Handbrake
Rebuilding Calipers
Soft Brakes
Air
Pulling
Squealing
Stuck Brakes
Main article: Brake Upgrades
