Intake
Air enters the system through an air filter, located behind the passenger side headlight. This is bolted directly to the AFM, a sensor that measures air flow. The air is carried from here by a rubber boot, which distributes air flow to the intake manifold in one of two ways. If the engine is idling, a small amount of air is allowed into the engine by way of an Intake#ICV, which is directly controlled by the ECU. The moment the throttle pedal is pressed, the ICV is switched off and the Throttle Body takes over, a mechanical door directly connected to the throttle pedal by a cable. The ECU senses that the throttle body is open by the TPS mounted underneath.
Air Filter
AFM
Rubber Boot
Throttle Body
Throttle Position Switch
ICV
The Idle Control Valve, or ICV, can be thought of as an electric door; it spins around at a certain rate, blocking and opening the passage so that only a specific flow of air can pass through it. It activates as soon as the ignition circuits are turned on, and should make a light buzzing noise.
Air Hoses
Intake Manifold
Lambda
Turbo
:Main article:
Controlling
Air Leaks
TPS Problems
K&N Filter
Replacing the existing air filter with a bolt-on aftermarket one is a cheap and popular modification to E30 engines, but Zone opinion is very heavily weighted against them. The standard BMW filter is more than adequate for standard engines, and replacement filters will only be needed after severe modifications to the rest of the engine.
Throttle Bodies
If you already have a 325i throttle body, and the rest of the M20B25 engine that does with it, the next step is an aftermarket upgrade known as a Big Bore Throttle Body, or BBTB. Learn more about BBTBs. [[Intake#
