Fuel
Revision as of 17:29, 13 October 2011 by Grrrmachine (talk | contribs)
To keep your E30 moving, it needs fuel. Since the majority of E30s use petrol injection engines, "Fuel" here is a synonym for "Petrol".
For Diesel engines, jump to the Diesel section of this page.
Fuel Tank
Filler Pipe
The primary source of fuel delivery into your tank.
Fuel Pump
The fuel pump is a relatively simple construction comprised of three components; the pump housing, the pump itself, and a fuel-level sender.
Fuel Level Senders
Fuel Filter
Fuel Lines
Fuel Hoses
Fuel Rail
Injectors
The injectors are the exit point of the fuelling system. They are electrically-operated solenoids which, when activated, squirt fuel at such high pressures that it atomises into a fine mist, which is the most efficient form for it to burn. The injectors are considered one of the most important components in a well-running engine, and one of the best ways to get more power from your old engine is to get the injectors back into good working order by cleaning them, and fitting new pintle caps if necessary.
Fuel Pressure Regulator
Carbon Canister
To meet increasingly stringent emissions regulations, later engines were fitted with a Carbon Canister. This small brown container sits in the engine bay and is bolted to the inner wing. It captures fumes from the fuel tank venting system, filtering them through a self-contained carbon filter and releases them into the throttle body. The carbon canister was controlled by a small electric valve. If you find an unused plug on the loom underneath the Intake#Throttle_Body, it is for this valve.
Controlling
The injection system is the main function of the ECU, be it L-Jetronic or Motronic. The ECU reads data on the engine from the Crank Position Sensor, and activates the fuel pump via the Fuel Pump Relay. This provides power directly to the fuel pump through Fuse 11,
The pump is controlled by the ECU, based on information it receives from the Crank Position Sensor, and is activated by the fuel relay.
No Fuel to Engine
The test to see if any fuel is reaching your engine is to detatch one of the hoses in the engine bay, put the end into a container (such as a water bottle) and then crank the engine. If fuel gets to the bottle, you have fuel. To do this:
  • Depressurise the system by removing Fuse 11 and cranking the engine
  • Undo the jubilee clip to the nearest accesible hose, pull the hose off and put the end into a securely-placed container
  • Replace Fuse 11
  • Check the bottle
  • Check Fuse 11
  • Identify and remove the Fuel Pump Relay. This is located in the engine bay, under a plastic relay holder with space for three relays only. On M20 engines, the relay holder is mounted next to the passenger side suspension turret. On M40 and M42 engines, the relay holder is mounted to the bulkhead next to the brake servo. The fuel pump relay SHOULD occupy the middle position; to confirm, check that the relay has a green/violet wire feeding it.
Fuel Smell (Inside)
Fuel Smell (Outside)
Fuel Leak
Fuel Leaks
Leak Location Cause Solution
Rich Running
Cold Start
The E30 fuel system is designed to be constantly under pressure, which means that it fuel should be pumped straight into the engine the moment the key is turned. If this doesn't seem to be happening, it's very likely that the system is losing pressure, which indicates a leak. Check all of your lines and hoses, especially with the engine running, and look for a mist or spray. Fix any leak immediately.
Hot Start
None at this time.
Diesel
The 324d and 324td were Diesel versions of the E30, and thus employed a standard diesel fuelling system.
