M42
Revision as of 19:50, 28 September 2011 by Grrrmachine (talk | contribs)
The E36 version adds a serpentine belt front pulley system and a different intake manifold. The M44 engine after 1995 was a 1900cc engine which produced 140BHP with 129 ft·lbf of torque and had a lowered redline of 6300RPM which is most commonly found in the E36 318iS
Characteristics
Dimensions (nominal) : 84mm/3.31" bore x 3.19" stroke
Displacement : 1796 cc
Camshaft : Duration: inlet 252 exhaust 252 Lift: inlet 10.2 exhaust 10.2
Lobe height: 1.8755-1.8803"
Con-rods : Max. weight variance without bearing shells: 4g/14oz split equally between big and small ends
Crankshaft : End play: 0.0031-0.0064"
Thrust on cylinder 4
Cylinders : Max. ovality: 0.01mm/0.0004"
Max. taper: 0.01mm/0.0004"
Cylinder head : Height = 140mm/5.512"; minimum height = 139.55mm/5.494"
Firing order : 1-3-4-2
Fuel Pressure : 43 psi
Oil pressure : 1.3-2.0 Bar/18 psi @ idle, 4.0-4.3 Bar/57-62 psi at 6250rpm
Oil Filter : Hengst E88H D24 in-bowl type
Oil Type : I would recommend a 5W40, 5W50 or 10W50 fully synthetic (the text book says 15W50) as the tappets seem to prefer a lower viscosity oil
Output : 134 (cat) -136 (non-cat) bhp @ 6000rpm; 127 ft-lb @ 4600 rpm
Pistons : Clearance: 0.0004-0.0016"
Piston rings : Gap: Top & bottom compression rings = 0.0080-0.0160" ; oil ring = 0.0080-0.0180"
Compression pressures : 10-11bar (143-156psi):
Torques : Big ends: Step 1 = 23Nm/17 ft-lbs, Step 2 = +70 degrees
Flywheel: 82-94 ft-lbs
Valves : Seat angle: 45 degrees
Valve clearance : None, automatically compensated by hydraulic tappets
Engine Bay
Identifying traits and points of interest in the above photo:
  • Individual coil packs
  • Twin-cam rocker cover
  • Twin-choke throttle (not-visible)
Profile Gasket
Gasket(x1): 111 217 215 46
Bolt set(x1): 111 217 219 39
Gasket (x1): 111 412 478 49
Gasket (x1): 111 412 478 37
o-ring (x1): 121 417 272 20
Gasket (x1):116 117 344 90
Gasket (x1):116 1173 468 4
o-ring (x1):115 3172 121 8
Gasket (x1):115 3172 117 2
Gasket (x1): 183 017 119 69
Nut (x4): 183 017 377 74
Timing Chain Tensioner
Tapping/ticking noise
Fuel smell
Lumpy idle
Common upgrades
Aluminium flywheels are becoming a more popular upgrade for the M42 engines. Replacing the dual mass flywheel with an aluminium version reduces the strain on the engine drastically. Instead of the stock 27 lbs the aluminium flywheel only weighs abouut 9lbs. The reduced weight means that the engine can acelerate alot faster because there is less load on the engine. However because there is less weight it does mean that between gear changes the revs drop very quickly so it is possible to stall the engine between changes. But owners who have got aluminium flywheels do say that you can get used to the drop in the revs and it soon doesn't become a problem by either quickly changing gear or bliping the throttle between gears to sustain revs. Unfortunately the standard duel mass flywheel has springs in the flywheel (and not the clutch) which reduce/stop chatter created. The aluminium flywheels do not have this so a quiet chatter can be heard and the idle can some times be lumpy. Not all M42's came with dual mass fly wheels which is a common misconception. A cheaper and more road freindly alternative to an aluminium flywheel is to fit an M20 flywheel and clutch assembley.
Most recently COP conversions have become popular. COP stands for Coil On Plug and locates a set of M50 coil packs onto the spark plugs as opposed to having the standard packs on the wing and HT leads.
Useful websites
BP's E30 318iS website
The M42 club
