Limited Slip Differential
E30s with LSD as standard
- UK Spec 325i Sport
- M3
Case sizes
E30 LSD Ratios
- 3.64 -
- 3.73 -
- 3.91 -
- 4.27 -
- 4.44 -
What oil to use for your LSD
External Links
Wikipedia's Limited Slip Differential Entry How Stuff Works - Differentials
