Limited Slip Differential
E30s with LSD as standard
Case sizes
E30 LSD Ratios
- 3.15 - M3
- 3.64 - prefacelft 325i
- 3.73 - automatic transmission 325i
- 3.91 - facelift 325i
- 4.27 -
- 4.44 -
What oil to use for your LSD
External Links
