Engine Swap - M42
Revision as of 18:33, 30 September 2015 by Rix313 (talk | contribs)
Identification
M44 crank sensor location:
M42 crank sensor location:
Parts List
You need:
  1. M42 engine
  2. E30 M42 engine loom and ECU (will work with E36 engines also, saves having to adapt E36 looms and causing issues!)
  3. E30 M40 or M42 engine mount arms
  4. E30 M42 engine mounts
  5. Coil packs and HT leads or COP conversion
  6. E30 M42 exhaust manifold
  7. E30 318iS exhaust system
  8. E30 M42 coolant hoses
  9. E30 M42 AFM to TB boot
  10. Getrag 240 gearbox
  11. 318iS propshaft
  12. E30-specific oil sump from an M40 or M42 engine. An M10 sump will not fit.
  • Radiator upper and lower mounts are different and need to be fabricated
  • Engine subframe/mounts are about 10mm too wide for the M42 engine legs
  • Coil pack needs to have a mount made and attached to hold in place
  • M42 engine requires a fuel pump in the tank, or in-line AND a fuel return pipe to be added. On many cars the wiring loom does cater for an in-tank fuel pump
  • On carburretted M10 engines the fuel tank will need replacing to provide an in-tank swirl pot.
  • Air filter needs a bracket / mount made
  • Wiring loom requires a swap (2 wires, oil and temp need swapping) and there is a LIVE off the engine loom the goes directly into and EARTH on the multi plug!
  • M40 or M42 instrument cluster. This is down to an issue with the temperature gauge.
Coil packs
Single mass:
Ancillaries
