Steering Rack Conversions
For starters, newer rack are physically a little bit shorter. This means that you need a pair of small metal spacers so that you can bolt the new rack in exactly the same location as the original rack. The pikey solution is to use a pile of washers, but a sturdier solution is to fabricate your own spacers or buy them ready-made. They need to be 8mm (Z3) or 14mm (E36/E46) tall, at least 14mm wide, with an internal hole of 10mm diameter.
Parts
- New Rack
- Rack spacers (8mm for Z3, 14mm for E36/E46)
Tools
- Ball-joint splitter
Which Rack?
Rack | Part Number | Turns
(lock to lock) |
Comments |
E30 | 4 | Standard power steering rack for all models | |
E36 | A perfectly adequate replacement for the E30. Nothing sporty, but certainly livelier than what the E30 left the factory with. | 3.4 | |
E36 M3 ('95) | 3.0 | Don't let the low lock-to-lock fool you. This rack is a variable speed unitm meaning it's ponderous in the middle and only rapid when it's close to full lock. In effect, this is the slowest of the E36 racks, and best avoided. | |
E36 M3 Evo ('96-) | 3.2 | Despite the lock-to-lock number, the E36 M3 rack isn't any faster than a standard E36 rack; it simply has massive locking plates fitted to it that limit the overall rack movements. Remove these plates, and it's a standard E36 rack. | |
E46 | 3.2 | A very good compromise between the older E36 rack and the wicked-sharp Z3. Cheap and plentiful too, but try getting a Clubsport rack if you can. | |
E46 Clubsport | 6 755 067 | 3 | The most popular choice these days, thanks to its speed and availability. Fitted to a range of E46s - look for the purple tag. |
Z3 | 3213 1094038
3213 1095577 |
It is critical that you do not touch the adjustment nut between the inner and outer tie rod. If you do, you will have to go through the whole process of having your steering geometry (tracking) adjust once the installation is complete. Leave them completely alone for now.
Steering Linkage
E36 hybrid
Ready-made
Guibo Delete
Opel Corsa C
Rack
Pipes
Now is a good time to get your pipes connected. If you've ordered cusom pipes, you'll need to fit one hose to your PAS reservoir and the other to your PAS pump. Don't forget to use new crush washers to prevent future leaks.
Track Rods
Now you just need to get your rack connected to your wheels. You'll need a set of inner or outer track rods (tie rods in Americanese) to do this.
Finishing
Complications
