Steering Rack Conversions
Revision as of 14:26, 27 April 2014 by Grrrmachine (talk | contribs)
For starters, newer rackers a physically a little bit shorter. This means that you need a pair of small metal spacers so that you can bolt the new rack in exactly the same location as the original rack. The pikey solution is to use a pile of washers, but a sturdier solution is to fabricate your own or buy them ready-made. They need to be 14mm tall, at least 14mm wide, with an internal hole of 10mm diameter.
Parts
  • New Rack
  • 14mm rack spacers
  • Inner and outer tie rods (complete set of either E30 or E36, but not E46)
  • Steering linkage (click here for more info)
  • New aluminium crush washers (14mm and 16mm)
Tools
  • Ball-joint splitter
  • 13mm, 15mm, 17mm, 19mm and 22mm sockets or spanners
  • A hammer and crowbar or suitable drift
Which Rack?
Rack Part Number Turns
(lock to lock)
Comments
E30 4 Standard power steering rack for all models
E36 3.4
E36 M3 3.2 Despite the lower lock-to-lock number, the E36 M3 rack isn't any faster; it simply has massive locking plates fitted to it that limit the overall rack movements. Remove these plates, and it's a standard E36 rack.
E46 3.2 While lock ratios are similar to others, the overall speed is noticeably slower. This isn't necessarily a bad thing though, as it doesn't feel twitchy at motorway speeds, unlike faster racks.
E46 Clubsport 6 755 067 3 The most popular choice these days, thanks to its speed and availability. Fitted to a range of E46s - look for the purple tag.
Z3 2.7 The fastest rack, and no need for a custom steering linkage, makes this the perfect rack. But most are now well over 20 years old, so finding a good one is increasingly difficult.
First thing to do is separate the tie rod ends from the suspension struts. For better access, turn the steering to each side. A 17mm thread lock nut holds the tie rod end to the strut so get this undone and then drop the tie rod from the strut. These two simple tasks can often be fraught with hassle due to parts being seized. If the balljoint spins while undoing the nut, place your jack under the ball joint and take the weight of the strut on the jack and try again to undo the nut. Failing that, another trick is to use heat such as a blowtorch, which can also work for removing the tie rod from the strut. A hammer and block of wood is also a commonly used way of separating the parts.
It is critical that you do not touch the adjustment nut between the inner and outer tie rod. If you do, you will have to go through the whole process of having your steering geometry (tracking) adjust once the installation is complete. Leave them completely alone for now.
Instead, prise off the metal ricg around the rubber boot at the steering rack end. Peel back the rubber to expose the nut on the inner tie rod, as well as the locking ring plate. The locking plate is a thin metal washer that has been bent over the tie rod nut to hold it in place. You need to bend the locking plate away from the nut, then get your spanner on the nut and give it a sharp twist. With luck, it'll start turning, allowing you to twist the entire tie rod assembly off the rack for re-use later.
Steering Linkage
E36 hybrid
Now, back to the hole in the disc. This is for the centering bush (similar to the nylon one on the E30 joint). If you look at the pinch bolt section you removed earlier, you should see a bronze bush in the centre. This is retained by some deformations (stakes ?) in the housing. With some careful drill work, the bush can be removed. It also helps if you cut through the side of the housing and open it up with a chisel. You need to make the hole in the centre of your new metal disc the same as the O/D of the bush. It needs to be a snug fit, and can be retained with some bearing securing solution (Loctite etc).
Ready-made
DanThe's steering linkage
Guibo Delete
Opel Corsa C
Rack
Rack mounted in the NON-PAS position
Spacers placed between top of rack and subframe
Pipes
Now is a good time to get your pipes connected. If you've ordered cusom pipes, you'll need to fit one hose to your PAS reservoir and the other to your PAS pump. Don't forget to use new crush washers to prevent future leaks.
Track Rods
Now you just need to get your rack connected to your wheels. You'll need a set of inner or outer track rods (tie rods in Americanese) to do this.
Finishing
Complications
318iS plastic under-tray modified for rack fitment.
Some 318iS owners have reported issues with steering linkage clearance when using the Z3 rack, so pay particular attention to which linkage you choose before starting. The plastic undertray on these cars can also interrupt with the fitment of the rack, so be prepared to cut away some of the plastic to make everything fit.
