Instruments
Revision as of 19:15, 12 September 2012 by Grrrmachine (talk | contribs)
Dash Cluster
SI Batteries
Coding Plug
Individual Gauges
Speedometer
Odometer
Fuel Gauge
Temp Gauge
Tachometer
Econometer
Dash Lights
Battery Light
Oil Pressure Light
Check Light
Brake Lights
Indicators
Main article: Indicators
Inspection Lights
OBC
Main article: OBC
Check Panel
Extra Gauges
VDO Gauges
Alpina
Alpina digital gauges
Speedo Not Working
Rev Counter Not Working
Fuel Gauge Not Working
Temp Gauge Not Working
The Temp Gauge is driven by the Brown Plug, a heat resistor that screws into the engine head. Failure of the brown plug is rare, but not uncommon. To test, first unplug the cable from the brown plug, and join the two terminals with a piece of wire. If you switch the ignition on, the gauge should go to full hot. If it doesn't, reconnect the cable and repeat the test by earthing pin 4 (brown/purple wire) of the C101 plug. If it now works, the issue is normally corrosion of the C191 plug.
