Instruments
Revision as of 19:25, 13 March 2012 by Grrrmachine (talk | contribs)
Dash Cluster
SI Batteries
Coding Plug
Individual Gauges
Speedometer
Odometer
Fuel Gauge
Temp Gauge
Tachometer
Econometer
Dash Lights
Battery Light
Oil Pressure Light
Check Light
Brake Lights
Indicators
Main article: Indicators
Inspection Lights
There is a cluster of LED's on the dash: five green, one red and one Yellow. Up to five green LED's will light when the ignition is turned on. However, the LED's will extinguish once the engine is started. When the yellow light comes on, service is due. When the Red light comes on, this means that service is overdue by approximately 1000 miles. Once the service has been completed, the service lights should be reset.
OBC
Main article: OBC
Check Panel
  • Coolant Level
  • Oil Level
  • Windscreen Washer Level
  • Front Lights (Dipped Beam)
  • Rear Lights
  • Numperplate Lights
  • Brake Lights
Extra Gauges
VDO Gauges
Alpina
Alpina digital gauges
