Engines Troubleshoot
Troubleshoot
| START | ||||||||
↓ | ← | Does the ICV buzz
with ignition on? |
run when cranking? |
| Starter Motor | Test CPS | ← | ← | ← | Check for spark | ← | ↓ | |
| Check for air leaks | ← | ← |
Solutions
Test Bulb On Coil
Bridge Wire To Coil
Green Wire
Charge Battery
Bridge DME Relay
Bridge Fuel Pump Relay
Bulb Across Fuel Pump
12V At ECU
Check for Spark
If you're not getting a spark from the coil, then you need to test the coil or replace it with a known working one. If you still don't see a spark, then you need to investigate the wiring linking the coil to the battery and to earth.
