Engines Troubleshoot
Troubleshoot
| START | ||||||||
↓ | ← | Does the ICV buzz
with ignition on? |
run when cranking? |
| Starter Motor | Test CPS | ← | ← | ← | Check for spark | ← | ↓ | |
| Check for air leaks | ← | ← |
Solutions
Test Bulb On Coil
Bridge Wire To Coil
Green Wire
The Ignition circuits are powered by a single green wire that runs through the interior of the car from the ignition switch to the ignition coil. This wire can be broken, damaged, interrupted by an immobiliser or the OBC, or simply not powered due to a broken ignition. Whatever the cause, we need to test it.
To start with, disconnect the [[C101] plug, and use a multimeter to check for continuity between the ignition coil pin 15 and pin 7 (Motronic) or pin 8 (Jetronic) on the engine side of the engine loom. If you don't have continuity, the wire is broken somewhere in the engine bay.
Charge Battery
Bridge DME Relay
Bridge Fuel Pump Relay
Bulb Across Fuel Pump
12V At ECU
Check for Spark
If you're not getting a spark from the coil, then you need to test the coil or replace it with a known working one. If you still don't see a spark, then you need to investigate the wiring linking the coil to the battery and to earth.
