Limited Slip Differential
Revision as of 21:02, 13 February 2012 by Grrrmachine (talk | contribs)
LSDs were fitted as standard to the 325i Sport and M3. They were not standard on the 318iS, but were on option available to all.
Case sizes
Ratios
   * 3.15 - M3
   * 3.64 - prefacelft 325i
   * 3.73 - facelift 325i
   * 3.91 - facelift 325i touring, cabrio, 325i with getrag 260 sport
   * 4.10 - found optionally on UK spec 318i/318iS 2/4dr in Small Case, and on all US M3 models in Medium Case.
   * 4.27 -
   * 4.44 -
Identification
To identify an LSD one can first check for the presence of the tag on the rear casing. The ratio on this will be prefixed with an S for LSDs.
Oil
