Instruments
Dash Cluster
SI Batteries
Coding Plug
Individual Gauges
Speedometer
Odometer
Fuel Gauge
Temp Gauge
Tachometer
Econometer
Dash Lights
Battery Light
Oil Pressure Light
Check Light
Brake Lights
Indicators
Main article: Indicators
Inspection Lights
OBC
Main article: OBC
Check Panel
- Coolant Level
- Oil Level
- Windscreen Washer Level
- Front Lights (Dipped Beam)
- Rear Lights
- Numperplate Lights
- Brake Lights
Extra Gauges
VDO Gauges
Alpina
