Interior
Dashboard
Instruments
Main article: Instruments
Controls
- Wash/Wipe stalk
- Indicator stalk
- OBC stalk - if fitted
- Hazard Lights
- Heater Controls
- Rear Demister
- Heated Seats - if fitted
Vents
Upholstery
Main article: Upholstery
Seats
Front Seats
Seat Belts
Rear Bench
Rear Seat Belts
Door Cards
Carpet
