Intake
Revision as of 08:28, 18 October 2011 by Grrrmachine (talk | contribs)
Air enters the system through an air filter, located behind the passenger side headlight. This is bolted directly to the AFM, a sensor that measures air flow. The air is carried from here by a rubber boot, which distributes air flow to the intake manifold in one of two ways. If the engine is idling, a small amount of air is allowed into the engine by way of an ICV, which is directly controlled by the ECU. The moment the throttle pedal is pressed, the ICV is switched off and the Throttle Body takes over, a mechanical door directly connected to the throttle pedal by a cable. The ECU senses that the throttle body is open by the TPS mounted underneath.
Air Filter
AFM
Rubber Boot
Connected to the AFM is a large black pipe known as the Rubber Boot. This pipe is specifically moulded to join the AFM to the throttle body, as well as providing air flow to other components including the ICV as well as the brake servo. A large variety of Rubber Boots were fitted to E30 engines during production, differing in the number and angle of the exit pipes.
Throttle Body
If you think the Throttle Stop has been tampered with, or you have stripped and rebuilt your throttle body, then the closing point can be reset using a XX feeler gauge between the door and the bore of the throttle body. However, to accurately set the throttle stop requires the services of an exhaust gas analyser.
Throttle Position Switch
ICV
The Idle Control Valve, or ICV, can be thought of as an electric door; it spins around at a certain rate, blocking and opening the passage so that only a specific flow of air can pass through it. It activates as soon as the ignition circuits are turned on, and should make a light buzzing noise.
Intake Manifold
Lambda
Turbo
Controlling
Idling
Possibly the most common problem on all E30s is a rough, lumpy or stalling idle of the engine.
Air Leaks
Stalling
TPS Problems
K&N Filter
Replacing the existing air filter with a bolt-on aftermarket one is a cheap and popular modification to E30 engines, but Zone opinion is very heavily weighted against them. The standard BMW filter is more than adequate for standard engines, and replacement filters will only be needed after severe modifications to the rest of the engine.
Throttle Bodies
MAF
