Instruments
Dash Cluster
SI Batteries
if the SI batteries have leaked, the entire circuit board will need to be replaced.
Coding Plug
Individual Gauges
Speedometer
The Speedometer is a very quick way of seeing which engine is fitted to your car.
Odometer
Fuel Gauge
Temp Gauge
Tachometer
Econometer
Dash Lights
Check Light
Brake Lights
Indicators
Main article: Indicators
Inspection Lights
OBC
Main article: OBC
Check Panel
- Coolant Level
- Oil Level
- Windscreen Washer Level
- Front Lights (Dipped Beam)
- Rear Lights
- Numperplate Lights
- Brake Lights
Extra Gauges
VDO Gauges
Alpina
