M42
Often referred to as an Engine crafted by God Himself.
The E36 version adds a serpentine belt front pulley system and a different intake manifold. The M44 engine after 1995 was a 1900cc engine which produced 140BHP with 129 ft·lbf of torque and had a lowered redline of 6300RPM which is most commonly found in the E36 318iS
M42B18 Engine as fitted to an E30 318is:
Identifying traits and points of interest in the above photo:
- Individual coil packs
- Twin-cam rocker cover
- Twin-choke throttle (not-visible)
The Profile Gasket
Gasket(x1): 111 217 215 46
Bolt set(x1): 111 217 219 39
Gasket (x1): 111 412 478 49
Gasket (x1): 111 412 478 37
o-ring (x1): 121 417 272 20
Gasket (x1):116 117 344 90
Gasket (x1):116 1173 468 4
o-ring (x1):115 3172 121 8
Gasket (x1):115 3172 117 2
Gasket (x1): 183 017 119 69
Nut (x4): 183 017 377 74
The Timing Chain Tensioner
Tapping/ticking noise
Fuel smell
Lumpy idle
The m42 engine is prone to the air breather pipes perishing. This results in unwillingness to start on cold mornings and a lumpy uneven idle. If you open the bonnet with the engine running you may be able to hear a hissing sound. Then all you need to play is hunt the sound considering there are alot of breather pipes to the engine. If there is no hissing sound it could be the valve in the idle control valve (ICV) sticking. Simply disconnect the ICV by undoing the jubilee clips (its found between the engine and bulkhead on the passenger side and is a "T" shape) and spray some carburettor cleaner into the valve. This should stop the valve from sticking, or you could replace the ICV completly.
Common upgrades
Aluminium flywheels are becoming a more popular upgrade for the M42 engines. Replacing the dual mass flywheel with an aluminium version reduces the strain on the engine drastically. Instead of the stock 27 lbs the aluminium flywheel only weighs abouut 9lbs. The reduced weight means that the engine can acelerate alot faster because there is less load on the engine. However because there is less weight it does mean that between gear changes the revs drop very quickly so it is possible to stall the engine between changes. But owners who have got aluminium flywheels do say that you can get used to the drop in the revs and it soon doesn't become a problem by either quickly changing gear or bliping the throttle between gears to sustain revs. Unfortunately the standard duel mass flywheel has springs in the flywheel (and not the clutch) which reduce/stop chatter created. The aluminium flywheels do not have this so a quiet chatter can be heard and the idle can some times be lumpy. Not all M42's came with dual mass fly wheels which is a common misconception. A cheaper and more road freindly alternative to an aluminium flywheel is to fit an M20 flywheel and clutch assembley.
Most recently COP conversions have become popular. COP stands for Coil On Plug and locates a set of M50 coil packs onto the spark plugs as opposed to having the standard packs on the wing and HT leads.
Useful websites
