How much is a new lambda sensor and idel control valve?
Weeman
Thu Apr 17, 2008 9:19 am
Just found out my idle problem on the 318is is linked to the lambda sensor (cat model) and the idle control valve, how much are these new from BMW so i have an idea on parts prices.
Thanks guys
DaveD
E30Zone Wiki Specialist
Thu Apr 17, 2008 9:29 am
Eurocarparts do the lambda probe a £60 but you can get them cheaper if you search.(they should be changed at 100k miles).and the idle control valve is £100 + but this is a common fault have a look at this
http://www.e36coupe.com/
go to technical and then "cleaning Idle control valve"
might be cheaper
Weeman
Thu Apr 17, 2008 9:40 am
Thanks matey
Thu Apr 17, 2008 10:28 am
A generic 4 wire lambda sensor will work fine, but you need to splice it to the loom and plug from your old one.
Your ICV will probably respond to a good clean. If not, try a second hand one. One of the great things about a 'quality' vehicle like an E30, is that there are very few 'weak points' where a failed component is also likely to have failed on scrap cars as well.
e30bmlover
Ac Schnitzer prophet
Thu Apr 17, 2008 10:42 am
i bought a spanking new icv L shaped icv for my b25.... it was £100 from gsf ( genuine bosch one )
