What is the best exhaust manifold to use ?
I can get a 323 one
m3 one or this one http://cgi.ebay.co.uk/BMW-E36-6-CYLINDE ... dZViewItem
M50 manifold
Ant
- Retired Team Member
as thats intended for the E36 I think the rearmost manifold will still foul the steering Ed
easily modded, as per the late E36 OE ones,
you could buy a cheap 6 branch to suit the e30 rhd and cut the flanges of and add M50 ones, that would defo fit as the port spacing is the same( although wider for the 24V obv )
Email FTW
http://cgi.ebay.co.uk/BMW-E36-6-CYLINDE ... dZViewItem As Ant says, the rear one will almost certainly foul the steering column, but, if you can weld stainless steel, it may work if you cut of the flange, remove most of the single pipe between the point where the three branches meet and the flange, then weld the flange back on at a slight angle to tilt the downpipe away from the steering shaft
ed325i
I will get the engine in and have a play with a m20 6 branch I have.
Thanks Ed
Thanks Ed
ed325i
This is the m20 6 branch fitted to m50 engine and the bit of wood shows where the steering went on the m20 so it might just work.
fowler
- Boost Junkie
looks like some heat and a gentle bit of persuaision required LOL
EX A-Tech Workshop bitch !!!
gone but not forgotten
ed325i
No I hadnt seen that.
I was looking at what they done when the alfa engine was fitted.
They moved the steering over abit.
http://www.e30zone.net/modules.php?name ... &start=150
ed325i
Got the engine in today.
Tried to fit the m20 6 branch the rear fitted ok but I cant get the front manifold in
