What size nut for O2 sensor?
Andy325i
Post Fri Apr 04, 2008 1:33 am
. . . and where can I get one :D
The O2 sensor is a Bosch unit from a 1995 530i (V8)
Many thanks
Andy
DaveD
E30Zone Wiki Specialist
Post Fri Apr 04, 2008 8:14 am
I didn't think O2 sensors had nuts?
Post Fri Apr 04, 2008 9:14 am
M18 X 1.5.
Bit of an unusual size, but my local fasteners supplier stocks them.
Andy325i
Post Fri Apr 04, 2008 2:51 pm
Thanx Brian!
Have tried:
Brenmark
Southwest fasterners
Woodbury Chilcott
both no joy :mad:
Kebrell have M18x1.5 in nylock or lock nuts which are apparently the same but half the height, so the guy suggested welding 2 together?
What is your supplier Brian?
Many thanks
Andy
appletree
Post Fri Apr 04, 2008 4:31 pm
is there any machining companys near you i got a bit of hex bar tapped out for a £5 and it was shaped to the exhaust :D
Andy325i
Post Fri Apr 04, 2008 5:27 pm
Thanx Appletree, will have a word with my machining guy :D but not sure that they will have a tap that size, as it seems a bit rare :(
Andy
ian332isport
Post Fri Apr 04, 2008 5:31 pm
Andy,
If you can't find a suitable nut (or someone to make you one), you can get something designed for the job from Demon Theives and the like (Merlin Motorsport, GPR etc).
Cheers,
Ian.
Post Fri Apr 04, 2008 6:40 pm
My supplier is: John Taylor Fasteners, Unit 5, Gratton Way, Barnstaple, EX31 3NL (01271 373212), and, when I asked a couple of years ago, when the same question was asked of me on an LPG group, they said they would be willing to supply by mail order.
A fairly thin nut is all you need, so you should be able to get what you want out of a nylock, and shape it to fit the down pipe.
**BANNED**
Post Fri Apr 04, 2008 6:51 pm
On my hottuning exhaust manifold there was a tapped hole that I asume is for an 02 sensor.It is the same thread/size as a 14mm spark plug...I got a blanking plug from my local Partco for a couple of quid,it was a Walker part.
Youth is wasted on the young.
Post Fri Apr 04, 2008 6:57 pm
daimlerman wrote:On my hottuning exhaust manifold there was a tapped hole that I asume is for an 02 sensor.It is the same thread/size as a 14mm spark plug...
M18 X 1.5 is spark plug size. I use a spark plug thread 'chaser' to clean out O2 sensor bosses as well as plug holes.
Post Fri Apr 04, 2008 7:34 pm
Got one here you can have Andy, its been cut out of an old 525i exhaust winkeye
Andy325i
Post Fri Apr 04, 2008 7:43 pm
Thanx guys, much appreciated :) :D
Where is the best place to locate the O2 sensor?
Andy
glenn
Engine Transplant Services
Post Fri Apr 04, 2008 9:11 pm
i have three spare one's here andy, off the m5 exhaust.
also got the m5 exhaust gas temp sensor.
i've also got a few bit's of exhaust here, with the bosses.
let me know if you need any of it andy
Jon_Bmw
Dangerous when thinking
Post Fri Apr 04, 2008 9:21 pm
Any place that custom makes exhausts will have one*, and they will probably give you one for nothing if you suggest you are probably going to come to them for a custom exhaust :)
*For example maniflow in salisbury.
Andy325i
Post Fri Apr 11, 2008 6:56 pm
Thanx guys, much appreciated too Glenn, will bear that in mind for the near future. I had to get a few bolts for the rear box today, so got a couple while I was there. Great guy and loves the E30's more than "the newer BMW's" and was well impressed when I told him what I had done. He also has an R32 Skyline as a play toy :D
I was worried that the "half height" nuts wouldn't have much thread, but there is more than enough there I think :)
Thanx again guys :D
Andy
