vauxhall powered e30....
BeemerShmeemer
Post Thu Mar 27, 2008 8:41 pm
after thinking about building a 2.5 turbo, why not use a turbo vauxhall engine i have sat in the garage. i only need pistons and gearbox(and another prop :roll: )
has it been done? i want to be a 1st to do somthing!
it should put down about 300bhp and wiegh less....
mikekean
Post Thu Mar 27, 2008 10:08 pm
do it cant be too hard. vauxhall motor is common on escorts as well as the cossie and people have put cossies in e30's so should go in. i was thinking about putting a 2.0 ford duratec in mine but its not been done before so dont know what issues i would of come across but i say go for it.
stonesie
Post Thu Mar 27, 2008 11:07 pm
O/T but 1 issue you might have with the ford duratec is that it's crap, theres little flaps in the plastic inlet manifold that are known to come adrift, not good for the engine at all.
On an old clarkson DVD theres a blue E30 with the C20XE vauxhall lump so its deffinatly possible to use the LET, which is vertually the same engine :wink:
mikekean
Post Thu Mar 27, 2008 11:40 pm
i wouldnt of dared putting it in with the plastic manifold. throtle bodys all the way. :twisted:
stonesie
Post Fri Mar 28, 2008 12:15 am
Your a sick man, but i like the sound of TB's :cool:
dobbie82
Location: Dolgellau, Wales (NOT A TRADER,broken a car,got lots of bits)
Post Fri Mar 28, 2008 4:12 am
I think you may need a bit of luck skill and a shoehorn... but it is something different :D
I have a 2.2 diesel turbo and the thing looks like its been squashed into the engine bay, I presume e30 engine bays are smaller?
good luck :-)
e30 related ebay auctions + shop(MY Stuff for Sale), http://tinyurl.com/64aufr
My Feedback on the e30zone: http://tinyurl.com/dobbie82feedback
chu346
Post Fri Mar 28, 2008 9:10 am
dobbie82 wrote:I presume e30 engine bays are smaller?
You shouldn't presume luv :D If you can fit a 5.0 v12 in you can fit a poxy 2.2 diesel or 2.0 4 pot in there.
Vauxhall and ford are rubbish 4 pot engines why would you want to ruin a bmw with one, please don't do it.
This thread is all about wrongness and people who do such a thing should be given a fine, 3 points and 10 days to remove it :D
BeemerShmeemer
Post Fri Mar 28, 2008 6:05 pm
lol i cant afford 3 more points. but i also cant afford to turbo a bm engine, so why not use the vauxh 1 i have..... thats the only reason i'm thinking of using vauxhall. as i know alot about them + its cheaper for me.
appletree
Post Fri Mar 28, 2008 6:50 pm
Why not sell the vaux lump then uase the money to turbo the BM :D winkeye
All in jest...
march109
Post Fri Mar 28, 2008 6:53 pm
Meh we got a cossie powered e30, a alfa powered e30, a few jap poered e30's why not a vauxhall one?
321gazza
Post Fri Mar 28, 2008 8:22 pm
hi beemershmeemer, do it do it do it,i have a red top turbo in my e30 as you said i had it in my garage from my opel manta, sold the manta shell kept the engine and wanted something better to put it in and hay presto bmw e30.would put pictures up but cant for the life of me do it shame thou :cry:
johnl320
Post Fri Mar 28, 2008 8:29 pm
Do it and post loads of pics up :D
fuzzy
He who sleeps with "Gingers"
Post Fri Mar 28, 2008 9:01 pm
go for it.if you have it sitting there it would be rude not to use it.
jaistanley
Post Sat Mar 29, 2008 8:24 pm
Damn right....
Though before buying the S50 I seriously toyed with the idea of fitting a Nissan SR20DET from an S14 200sx.I quite like the idea of a 2.3 Duratec on TB's too in a stripped out racer type affair. In a road car its all about te torque though... winkeye
321gazza
Post Mon Mar 31, 2008 8:17 pm
Are you going to do it man, mine should be running soon,i have not yet heard of this engine swop before thou,so i can be the uks first vauxhall powered e30 winkeye :D but this engine is only to set the car up as i might be putting a saab 2.3 turbo in as it bolts up to my vauxhall omega gearbox good times ahead aaahhh yea :twisted: :D
jaistanley
Post Tue Apr 01, 2008 11:57 am
Those Saab engines are awsome. How does the sump orientation and manifolds suit the E30?
All steel internals and very good pistons from factory. Internals are said to easily be good for 500bhp in an engine you can pick up at the breakers for pennies!
