intensive wash woes
gazza
Mon Mar 24, 2008 1:06 pm
what component would be the first place of call if my headlight intensive wash set up works on every application of the screen wash arm ....not the intensive function. it works even with the lights off .....not a bad problem but im forever filling the reservoirs up....the relay in the fuse box or the one attached to the reservoirs ....or what else should i look at
rj
Mon Mar 24, 2008 3:37 pm
The headlight wiper system is triggered by the normal windscreen wipers and not the intensive wash system. It should operate every 5th time the windsreen washers are used, when the headlights are switched on.
The o/s headlight wiper motor is responsible for triggering the headlight washers. Quite often, when the the headlight washers incorrectly operate all of the time, it is due to a seized or incorrectly parked o/s headlight wiper.
Therefore firstly check the headlight wiper is completing it's sequence and parking correctly.
beardymat
Mon Mar 24, 2008 3:43 pm
sounds spot on to me as i have the same thing happening and my o/s motor is definately siezed. its on the to do list :D
gazza
Mon Mar 24, 2008 8:49 pm
many thanks ill have a look
oze30
Mon Mar 24, 2008 8:52 pm
I wish mine worked!! :(
gazza
Mon Mar 24, 2008 8:56 pm
you dont need them col .....maybe some roo bars
