ms
I am not very bright
Post Fri Mar 21, 2008 9:51 am
what is a ms is it better then a piggy back unit
Turbo-Brown
Boost Junkie
Post Fri Mar 21, 2008 9:57 am
MS or MegaSquirt is a full engine management system which replaces the original ECU and assumes control over engine functions like idle control, fueling and ignition.
A piggyback modifies the behavior of the standard ECU.
Post Fri Mar 21, 2008 10:06 am
so it would be better to go for the ms if im right
Turbo-Brown
Boost Junkie
Post Fri Mar 21, 2008 10:08 am
I would say so :)
Post Fri Mar 21, 2008 10:11 am
how much does it cost
mattG
Post Fri Mar 21, 2008 10:14 am
MS will allow you to run bigger injectors and has programable outputs to control lots of other things, electric fan, nos, boost control etc.
(\__/)
(='.'=)Simon13 wrote:
323's were dangerous this will un drivable in the wet!
MattG - hedgefinding specialist
E21 turbo
Can be your new sig matt!
Post Fri Mar 21, 2008 10:15 am
thanks for that but does it control rpm
mattG
Post Fri Mar 21, 2008 10:20 am
e30power wrote:thanks for that but does it control rpm
It will run every aspect of your engine replacing your existing ecu, rev limits, timming every thing :cool:
(\__/)
E21 turbo
Post Fri Mar 21, 2008 10:23 am
so do you now how much it costs
mattG
Post Fri Mar 21, 2008 10:34 am
e30power wrote:so do you now how much it costs
The price varies alot depending on what you want ie options fuel & spark only or full monty with lots of outputs, diy or fully installed.
Mine was done a couple of years ago so not sure on the price at a guess £300-£700 depending on diy, fully installed & mapped.
(\__/)
E21 turbo
Post Fri Mar 21, 2008 10:52 am
i would like to buy 1 already made
mattG
Post Fri Mar 21, 2008 11:02 am
(\__/)
E21 turbo
Post Fri Mar 21, 2008 1:09 pm
i have been doing some resarch and ms has problems is that true
Post Fri Mar 21, 2008 1:13 pm
See this site by Flappysocks, who has written a guide on building and fitting them.
http://www.diyefi.co.uk/
