ms
I am not very bright
what is a ms is it better then a piggy back unit
Turbo-Brown
- Boost Junkie
MS or MegaSquirt is a full engine management system which replaces the original ECU and assumes control over engine functions like idle control, fueling and ignition.
A piggyback modifies the behavior of the standard ECU.
so it would be better to go for the ms if im right
Turbo-Brown
- Boost Junkie
I would say so
how much does it cost
mattG
MS will allow you to run bigger injectors and has programable outputs to control lots of other things, electric fan, nos, boost control etc.
(\__/)
(='.'=)Simon13 wrote:
323's were dangerous this will un drivable in the wet!
MattG - hedgefinding specialist
E21 turbo
Can be your new sig matt!
thanks for that but does it control rpm
mattG
It will run every aspect of your engine replacing your existing ecu, rev limits, timming every thinge30power wrote:thanks for that but does it control rpm
(\__/)
E21 turbo
so do you now how much it costs
mattG
The price varies alot depending on what you want ie options fuel & spark only or full monty with lots of outputs, diy or fully installed.e30power wrote:so do you now how much it costs
Mine was done a couple of years ago so not sure on the price at a guess £300-£700 depending on diy, fully installed & mapped.
(\__/)
E21 turbo
i would like to buy 1 already made
mattG
Contact Ant he the MS guru on here,
details http://www.e30zone.net/modules.php?name ... ofile&u=10
http://www.e30zone.net/articles/misc/atech.jpg
(\__/)
E21 turbo
i have been doing some resarch and ms has problems is that true
See this site by Flappysocks, who has written a guide on building and fitting them.
http://www.diyefi.co.uk/
