Dying carpet Black..with pics
eko
Old timer
Post Mon Mar 17, 2008 10:52 pm
Ordered some Black dye to do my carpet and a few other bits.
Was planning on using a sponge to do some of it but do I need a soft sponge or hard sponge? :o:
Id imagine it`d be the hard otherwise the soft sponge would drink all the dye but never done this before so no harm asking :D
cliffybabe
Powered by Nelly
Powered by Nelly
Post Mon Mar 17, 2008 11:58 pm
Tony this link is my Guru for carpet dying
http://www.e30zone.net/modules.php?name ... carpet+dye
hope it helps
eko
Old timer
Post Tue Mar 18, 2008 12:12 am
Perfect Neil thanks :D
Bought 5lts of the stuff so going to go mad with it...carpet/rooflining/shelf etc.Might even do the boot linings too winkeye
cliffybabe
Powered by Nelly
Powered by Nelly
Post Tue Mar 18, 2008 12:15 am
:lol: no worries i bought the same gear from the link, good luck
DaveD
E30Zone Wiki Specialist
Post Tue Mar 18, 2008 9:20 am
The best way to put it on the carpet is to get a hand spray bottle (from a kitchen spray) and fill it with the dye, take all the interior, including the centre console, out and cover all that's left(wiring gear lever etc. ) with plastic bags and spray the carpet , while you are doing this have a nylon scrubbing brush and brush the wet carpet so as to let the dye soak in and cover evenly...
It will cover the plastic heel rest ..but unevenly ..it's trial and error...the main thing is do it on a dry day with all the windows open and try to leave it for as long as possible after you have finished ..not because it doesn't dry ..the fumes will knock you out.....and use heavy duty rubber gloves as well ....be warned
Looks good when finished though
eko
Old timer
Post Tue Mar 18, 2008 6:49 pm
Cheers Dave.
hopefully ill make a start on it this weekend winkeye
aceraf
Post Tue Mar 18, 2008 7:07 pm
Can I ask that you put pics up of your finish, and advise on durability.
Someone asked a question on the other thread about the dye coming off onto white trainers, can anyone shed some light on that?
Breaking 325i Touring
eko
Old timer
Post Tue Mar 18, 2008 7:10 pm
aceraf wrote:Can I ask that you put pics up of your finish, and advise on durability.
Ill take plenty of before/during/after pics of my progress.
Think ill do my headlining first though as no doubt thats going to be the messiest :mad:
I also wear White trainers so ill keep you updated :o:
DaveD
Post Tue Mar 18, 2008 7:13 pm
If its the valeterspride dye..the durability is great ,it does not come off, but it makes the carpet a bit harder and my light grey carpet is not really jet black but more of a very very dark charcoal grey...this is after 1 year...really very pleased with it :D
and it doesn't take long once you start spraying but don't expect to want to drive the car for quite a bit after you've finished (FUMES)
eko
Old timer
Post Tue Mar 18, 2008 7:33 pm
It wont be driving anywhere for a couple of months at least :D
d6dph
Post Tue Mar 18, 2008 8:11 pm
Tony, May be worth getting one of those painters overalls to stop you giving yourself a heavy duty fake tanning session.
you will look like a complete tit, but a clean one! :D
eko
Old timer
Post Tue Mar 18, 2008 8:14 pm
d6dph wrote:Tony, May be worth getting one of those painters overalls to stop you giving yourself a heavy duty fake tanning session.
Lol ill be wrapping up well winkeye
OBs
Post Tue Mar 18, 2008 8:18 pm
I supply you with some 'Forensic whites' if you like Tony :mad:
You would be better getting me to spray the heal bits as discused Tony, Ill pop over on Sat/Sun if you like...
What about doing Chris's car?
I think he needs a wheel bearing???
o22ie
Post Tue Mar 18, 2008 8:22 pm
I did my blue carpets and got pretty good results,
deffo need the gloves though, the stuff goes everywhere
eko
Old timer
Post Tue Mar 18, 2008 8:29 pm
OBs wrote:I supply you with some 'Forensic whites' if you like Tony :mad:
Grab me some Whites if you will mate,gonna be messy doing it :mad:
Not heard from Chris as yet?
tailoutcharlie
Post Tue Mar 18, 2008 11:04 pm
oohhhh i wanna do my headlining and carpets now :D
should contrast nicley with the houndstooth seats winkeye
if you have any left tony ill take it off your hands :thumb:
Chris
Pyros
Post Wed Mar 19, 2008 1:39 pm
how much do you reckon you would need to do rear shelf, headliner and carpets, and what would be the best way to dye the back seats or is it easier to get black ones
DaveD
Post Wed Mar 19, 2008 1:45 pm
you need 1.5 litres to do the carpet properly ...i got away with 1 JUST! so about 2 1/2 for the lot..... if you are just doing a re dye of the seats either gliptone or furnitureclinic ... do a search
eko
Old timer
Post Wed Mar 26, 2008 11:25 pm
Well finally got to have a go with the dye.Thought id start on my parcel shelf first.
Ended up using about half a litre on the thing so think im being a bit hasty with it.
Anyway it has come out ok.I did the actual blind too but im not happy with the finish on that(bit shiny/patchy) so will probably try and wipe it off and just spray it Satin Black.
Next job is start taking out the windows etc to do the roof lining winkeye
Pyros
Post Thu Mar 27, 2008 9:58 am
wouldn't it be easier masking the windows and everything else instead of taking the windows out?
DaveD
Post Thu Mar 27, 2008 10:05 am
1/2 a litre!!! I managed with 1 for the whole carpet..are you brushing as you spray to get an even covering..also i would wipe the headlining over with something to take any possible grease off it...you wont run into problems of uneven coverage :)
cliffybabe
Powered by Nelly
Powered by Nelly
Post Fri Mar 28, 2008 1:06 am
how long does it take for the dye to dry?
eko
Old timer
Post Fri Mar 28, 2008 1:21 am
DaveD wrote:1/2 a litre!!! I managed with 1 for the whole carpet..are you brushing as you spray to get an even covering..also i would wipe the headlining over with something to take any possible grease off it...you wont run into problems of uneven coverage :)
Dave ill be honest...I did try brushing it in but I bthink the brush I used was to hard so just sprayed loads on till it was even :o:
Ive learnt though and today started doing my carpet,this time using an old soft nail brush.
The results?Well lets just say im chuffed to bits :P After stripping out the seat/lower trim etc which took about an hour,gave it a good hoover out and made a start.Covered really well and using the soft brush made it so much easier.
Felt dry well within an hour but left it with the windows open an inch to air/dry overnight.
Ill take some pics and post up tomorrow.
cliffybabe
Powered by Nelly
Powered by Nelly
Post Fri Mar 28, 2008 1:23 am
Cheers Tony :thumb:
eko
Old timer
Post Fri Mar 28, 2008 1:25 am
Neil the results are well worth the effort
Im going to go mad and do the boot carpet/sides too :D
Rooflining next though which is major stripdown/windows out etc :mad:
cliffybabe
Powered by Nelly
Powered by Nelly
Post Fri Mar 28, 2008 1:26 am
eko wrote:Neil the results are well worth the effort
cool cool, what coulour was ur carpet to start with T???
eko
Old timer
Post Fri Mar 28, 2008 1:29 am
The usual pale Grey as fitted to all poverty spec 316`s :P
Going to dye a set of Grey mats too,no reason why they wont be as easy winkeye
cliffybabe
Powered by Nelly
Powered by Nelly
Post Fri Mar 28, 2008 1:33 am
Poverty Grey, U mean war reject style :twisted:
I've just been given a blue carpet which im gonna try it on :cool:
Dying the mats should come up good to, I was gonna spray/ dye my leather horse shoe ont he cab till i spoke to dips, Now he is giving it the dips appeal winkeye
eko
Old timer
Post Fri Mar 28, 2008 6:04 pm
Heres a few pics.
Not the best as they are either too bright or too dark.
The heel mat and pad at the side of the accelerator pedal was done with Satin Black paint with some sort of etch primer OBs had.
Just done the mats with the dye too :D
Before...
After...
cliffybabe
Powered by Nelly
Powered by Nelly
Post Fri Mar 28, 2008 6:17 pm
looks wel good dude :cool:
OBs
Post Fri Mar 28, 2008 7:06 pm
eko wrote:Heres a few pics.
Adhession promotor :wink:
Nice job mate, looks nice, seats next winkeye :D
OBs
DavieP
Post Sat Mar 29, 2008 10:59 am
Really nice job Tony - are you leaving the seats the same colour? I've toyed with the idea of doing something similar to mine, but I think I'll stick with the dark grey and anthracite ... unless my boat comes in and enables me to afford a total leather re-trim with co-ordinated wilton carpets.
Dave in Torquay
eko
Old timer
Post Sat Mar 29, 2008 12:00 pm
DavieP wrote:Really nice job Tony - are you leaving the seats the same colour? I've toyed with the idea of doing something similar to mine, but I think I'll stick with the dark grey and anthracite ... unless my boat comes in and enables me to afford a total leather re-trim with co-ordinated wilton carpets.
Soon as i find a replacement bolster for the front seat ill probably sell the M3 interior and go for Black leather winkeye
madaboutthe30
Post Sat Mar 29, 2008 12:08 pm
Nice one!!
Dreaming of the day I purchase an E30 M3
--- e30 motorsport cab-- in the process of becoming a trailer queen
--- Z4M Coupe - daily driver
OBs
Post Sat Mar 29, 2008 11:37 pm
I saw the carpet in the 'flesh' today, top job :D
Nice shade of black (Looks factory)
Like Eko said it has made it a tad rough but will mature with age winkeye
OBs
