Afternoon folks.
I'm just mulling over this supercharger project and when the brackets are ready I see my big challenge will be relocating the alternator.
I really need to find out what brackets I can fit to the exhaust side of the black that will do the job.
Does anybody know off-hand what options I've got? I'm shit at fabrication and that kind of thing so bolt-on is ideal - I think I can cope with spacers to line the pulleys up etc so I don't think that's too much of an issue as long as it's in the ball park.
Advice is appreciated!!!
Moving the alternator
hoshy
- E30 Zone Wiki Guru
- **BANNED**
Air con compresser bracket?
Youth is wasted on the young.
n1tr0_9
I find having some rough measurements as a guide, and then a trip round a few breakers yards always helpful. Sometimes you can find something that will work with out having to fabricate stuff.
hoshy
Thanks guys. Nitro, I'm hoping that there's a bracket such as the air-con one such as daimlerman suggests, for either the m42 or another engine, that will do the job. I'm trying to avoid hours in the breakers yard
- **BANNED**
M20 engine may supply on air con bracket,not to sure about fit on an M42...any tapped holes low down on the exhaust side?
hoshy
Yeah - I think there's actually two sets.
320Touring
You gonna have an electromagnetig clutch to disengage the charger?
or alternatively - you could mount alternator on the intake side- and drive it off same belt as the charger? Wiring loom has some play so you can maybe mount it on wing next to PS reservoir?
hoshy
Unfortunately clutched charger is out. but it's still gonna be
appletree
I thought about this abit back and was thinking of using the same bracket upside down and the make a 10mm plate which had the holes for the alternator bracket and then drill the holes in it to mount it to the air con bracket, then you can move the alternator bracket it up/down on the side of the block till it fits best
than marke were the plate sits and dril lthe air con bracket hole in it or any othere threaded holes on the exhaust side of the block
hoshy
matt. you're a fucking genius!
Pretty soon I'll have my charger running with advice like that. Are you up for the drag strip? two m45 charged iS monsters
appletree
Should think i'll be there ya
