2.8 build question
320ise
Post Tue Feb 19, 2008 2:18 pm
do you have to use an m52 crank? or could you use any other m50 crank? allso what sort of price does it cost to have the spacer fabricated? newby to engine building after learning as i go lol!
Templ8e30
Post Tue Feb 19, 2008 3:01 pm
M52B28 crank only mate.
Avoid the M52B28TU (twin Vanos) crank, it doesn't fit.
Cheers,
Iain T
2007 Mazda 6 2.0 estate
ed325i
Post Tue Feb 19, 2008 3:29 pm
Mine cost £15 to get done.
Turbo-Brown
Boost Junkie
Post Tue Feb 19, 2008 5:22 pm
I believe the TU crank does fit with minimal mods to the block.
Templ8e30
Post Tue Feb 19, 2008 9:42 pm
Turbo-Brown wrote:I believe the TU crank does fit with minimal mods to the block.
Not so, I had a TU crank and found that minimum mods will alow the crank to rotate in the block BUT the counter weights are too large and foul the bottoms of the pistons to within 2mm of the gudgeon pin.
The only way you can use the TU crank is to use custom forged pistons and the 325i (135mm) conrods.
Cheers,
Iain T
march109
Post Tue Feb 19, 2008 9:45 pm
I have a TU and non TU crank, fortunatly I am also using custom pistons and 135mm rods.
Turbo-Brown
Boost Junkie
Post Tue Feb 19, 2008 10:29 pm
I'm worried now! Do have 135mm rods and custom pistons but didn't tell them I was using the TU crank.
Oh well, it's only money :lol: Shouldn't be too long before I can do a trial build and find out for sure!
Andyboy
Alpina Colada
Post Wed Feb 20, 2008 6:49 pm
Non TU crank, 130mm rods and late 325i 8.8:1 pistons. The non TU crank is much more common due to old age and the Nikasil dramas. No block or crank machining, just screw it together. Make the spacer from the M52 front pulley hub - about 20 minutes work in a lathe.
