2.8 build question
320ise
do you have to use an m52 crank? or could you use any other m50 crank? allso what sort of price does it cost to have the spacer fabricated? newby to engine building after learning as i go lol!
Templ8e30
M52B28 crank only mate.
Avoid the M52B28TU (twin Vanos) crank, it doesn't fit.
Cheers,
Iain T
Cheers,
Iain T
2007 Mazda 6 2.0 estate
ed325i
Mine cost £15 to get done.what sort of price does it cost to have the spacer fabricated?
Turbo-Brown
- Boost Junkie
I believe the TU crank does fit with minimal mods to the block.
Templ8e30
Not so, I had a TU crank and found that minimum mods will alow the crank to rotate in the block BUT the counter weights are too large and foul the bottoms of the pistons to within 2mm of the gudgeon pin.Turbo-Brown wrote:I believe the TU crank does fit with minimal mods to the block.
The only way you can use the TU crank is to use custom forged pistons and the 325i (135mm) conrods.
Cheers,
Iain T
march109
I have a TU and non TU crank, fortunatly I am also using custom pistons and 135mm rods.
Turbo-Brown
- Boost Junkie
I'm worried now! Do have 135mm rods and custom pistons but didn't tell them I was using the TU crank.
Oh well, it's only money
Shouldn't be too long before I can do a trial build and find out for sure!
Andyboy
- Alpina Colada
Non TU crank, 130mm rods and late 325i 8.8:1 pistons. The non TU crank is much more common due to old age and the Nikasil dramas. No block or crank machining, just screw it together. Make the spacer from the M52 front pulley hub - about 20 minutes work in a lathe.
