Painting the ignition coil
greentouring
Can this be done and has anyone got any pics if so?
whipsey
you can paint anything mate so should be an easy job
zaust
- Zone day release
- Location: Somewhere in Hertfordshire , or press Ctrl + W
cliffybabe
- Powered by Nelly
an old skool bug manzaust wrote:I use a stella can. Much easier...
greentouring
A Stella can? How does that work then? Any pictures?zaust wrote:I use a stella can. Much easier...
I'm just doing mine black.......can I use any spray paint on this?
whipsey
drinks can wrapped around the coil as long as you key the the coil you can spray it with cans etc
greentouring
Okay, thanks for that, will get painting next week...;)
Taylor325i
- Location: Kilmarnock, Ayrshire, Scotland. Brilliant Red Tech II 325i.
Better off with a Guiness
Taylor.
Taylor.
Taylor, I notice you don't have any sound/heat proofing foam on the underside of your bonnet - does this cause any adverse effects with paintwork, etc?
Taylor325i
Speedtouch wrote:Taylor, I notice you don't have any sound/heat proofing foam on the underside of your bonnet - does this cause any adverse effects with paintwork, etc?
No mate, no problems at all and it's been like that for 4 years.
Taylor.
Cool. Might remove my rottweiler-spec underbonnet foam then
Taylor325i
I hope you are a patient man - it's a nightmare of a job. I took the bonnet off and pressure washed most of the old foam off. Then it was a lot of T-Cut and elbow work to remove the sticky glue. Then several layers of polish and wax. There might be an easier solution to it but that was my method.
Taylor.
Taylor.
