Painting the ignition coil
greentouring
Post Sun Feb 10, 2008 3:54 pm
Can this be done and has anyone got any pics if so? :?
whipsey
Post Sun Feb 10, 2008 7:27 pm
you can paint anything mate so should be an easy job
zaust
Zone day release
Post Sun Feb 10, 2008 7:29 pm
I use a stella can. Much easier...
M30 Tech 1 Touring on gas.
cliffybabe
Powered by Nelly
Powered by Nelly
Post Sun Feb 10, 2008 7:58 pm
zaust wrote:I use a stella can. Much easier...
an old skool bug man winkeye
greentouring
Post Sun Feb 10, 2008 8:34 pm
A Stella can? How does that work then? Any pictures?
I'm just doing mine black.......can I use any spray paint on this?
whipsey
Post Sun Feb 10, 2008 8:45 pm
drinks can wrapped around the coil as long as you key the the coil you can spray it with cans etc
greentouring
Post Sun Feb 10, 2008 10:22 pm
Okay, thanks for that, will get painting next week...;)
Taylor325i
Location: Kilmarnock, Ayrshire, Scotland. Brilliant Red Tech II 325i.
Post Sun Feb 10, 2008 10:26 pm
Better off with a Guiness winkeye
Taylor.
Post Sun Feb 10, 2008 10:34 pm
Taylor, I notice you don't have any sound/heat proofing foam on the underside of your bonnet - does this cause any adverse effects with paintwork, etc?
Taylor325i
Post Sun Feb 10, 2008 10:37 pm
Speedtouch wrote:Taylor, I notice you don't have any sound/heat proofing foam on the underside of your bonnet - does this cause any adverse effects with paintwork, etc?
No mate, no problems at all and it's been like that for 4 years.
Taylor.
Post Sun Feb 10, 2008 11:04 pm
Cool. Might remove my rottweiler-spec underbonnet foam then :)
Taylor325i
Post Mon Feb 11, 2008 5:24 pm
I hope you are a patient man - it's a nightmare of a job. I took the bonnet off and pressure washed most of the old foam off. Then it was a lot of T-Cut and elbow work to remove the sticky glue. Then several layers of polish and wax. There might be an easier solution to it but that was my method.
Taylor.
