G60 supercharger on a m42
Emm3
Post Sat Feb 09, 2008 12:03 am
I've seen a few m42's supercharged with the mini charger and was wondering if the Vw G60 charger would be any good. A mate of mine has a g60 Corrado and with a few mods and smaller pulley the charger pushes 22psi and 240 bhp. To look at the charger is quite a simple design.
appletree
Post Sat Feb 09, 2008 7:16 pm
supose it could work, its only making boost so it doesnt matter whats making it, the only problem i could see is that after all the custome install the charger would need rebuilding every 50,000 miles ( i think that what the rebuild time was) so if you going to all the effort you would probly be better to use a rotex type charger that would last alot longer.
Also not sure on the effeicency and boost characteristics of the vain type charger :D
CHRISP
Boost Junkie
Post Sun Feb 10, 2008 7:51 pm
If you are looking for a supercharged kit then talk to ANT he will help you!
318 turbo cab mint for sale offersImage
Turbo-Brown
Boost Junkie
Post Sun Feb 10, 2008 8:02 pm
Anyone else ever get the feeling that VW made the G-LADER supercharger as one of their "for the sake of it" exercises? A bit like their god awful "W" engines.
cliffybabe
Powered by Nelly
Powered by Nelly
Post Sun Feb 10, 2008 8:09 pm
as chris said ant is doing a supercharger kit at present
corsashmorsa
Post Sun Feb 10, 2008 10:17 pm
no offence to anyone but maybe he asked about using a charger off another car as he might have a low budget(like me all the time) for most of you the charger kit might be cheap but alot of us it isnt so we have to use what we can get hold if via the scrappy etc
jkarran
Post Mon Feb 11, 2008 10:50 am
Turbo-Brown wrote:Anyone else ever get the feeling that VW made the G-LADER supercharger as one of their "for the sake of it" exercises?
It certainly looks like that doesn't it. It couldn't be much more complicated or fragile yet doesn't perform much better than the simple roots blowers.
I guess the justification may have been that it's simpler to make (or was at the time) than a twin screw compressor, doesn't have the seal/guide wear problems of the sliding vane designs and doesn't suffer the horrible inefficiency problems of the roots designs.
As for putting one on an M42... you could no doubt do it and it'd probably work very well but for your money you'll get a much better condition Eaton roots blower that will do much the same job and wont blow up if you look at it funny :)
jk
E30 320i Rally Turd - Usually broken
E24 635Csi - Rotting in peace for now
E34 540i - Daily driver
Blown R1 Striker - In progress
