right. I am doing the above conversion and need help on parts needed as i am getting evrything together.
list of what i have:
Engine
Box
Ecu+loom
Brakes
What am i missing?
is the 325 Radiator different? pretty sure it is.
will i need prop from 325?
Slave cylinder?
Also is the Manifold different on cabs than coupes?
318 to 325 conversion
nav786
FOR SALE
SONY PSP'S £100
Davenotouring
You will need to change the prop yes..
I think the manifolds are different for the cab, check the group buy, where they are having to do different ones for cab/coupe.
1.8 suspension may not be strong enough at the front....might sit a bit low, but that's not essential
Probably a couple more points.....
Will be good once it's done!
BMW 328i Cab - Daily Slag
Adam318i
I want to do this conversion to, probably next year tho when i have some No claims discount.
Is it easiest to just buy a doner?
I'll try nearer the time getting one thats rusted everywhere and has ripeed intiror.
Then i'll be sorted.
Hope all goes well with it Nav
Adam
Adam
I love my Rice!
Far easier to buy a doner
buster
im sure the front suspension will need to be changed as i think it will be far to low and unsafe at the front.
Not to mention the brakes.
That's why it's far easier with a doner.
nav786
i have just fit the spax kit all round. would that not be ok?
and what about the radiator, is it different. must be bigger
FOR SALE
SONY PSP'S £100
Davenotouring
They are listed as different on the GSF site, so I would guess, as you say the rad is bigger on the 2.5
nav786
what about the power steering pipes. i hear the 318 pipes will be too short, so will i need pipes form 325. would these work?
FOR SALE
SONY PSP'S £100
Templ8e30
I'm currently doing this conversion on Fastcarz 318i cab. We have changed:
1. Engine loom/ECU/AFM
2. Auto 2.5 engine converted to manual with spigot bearing and manual flywheel.
3. 325i gearbox
4. 325i prop
5. 325i 3.73 diff
6. 325i 3 piece exhaust
7. Complete 325i steering rack/pump/hoses
8. 325i rad & expansion tank etc
The exhaust is new for a 325i coupe and all fits perfectly, don't know where all this talk of different manifolds and downpipes comes from
We have a donor car and is much easier than faffing about buying individual bits.
Cheers,
Iain T
3. 325i gearbox
4. 325i prop
5. 325i 3.73 diff
Cheers,
Iain T
2007 Mazda 6 2.0 estate
- Homo Hair
a donor car is a great idea except i got no where to put it
nav786
Templee30- how comes you are changing the steering rack? is it vital or just enhancement?
FOR SALE
SONY PSP'S £100
Templ8e30
I changed the rack because the power steering pipes aren't long enough to mount the pump in the right place, so to avoid messing about I swapped the whole system over.
It's only held in with 2 bolts/2 balljoints and the steering coupling !
Cheers,
Iain T
Cheers,
Iain T
