E30 320i SE MPG
Hi is 30 MPG good for an E30 320i SE 1988, she's managed 34 MPG on a 300 mile motorways only journey cruising at 70, she's being used as a daily driver as she has only done 116,000 miles un molested apart from a full stardard size stainless steel exhaust system not strait through, just wanted to make sure shes running correctly and all above board, shes just had a full service and a full set of new bridgestone tyres. Other than one tyre being given an advisory she sailed through her MOT
i'm gradually going to start replacing all sensors over the coming months and change coil, and rotor arm, dizzy cap
I'd be tempted to leave it well alone if it's running that well!
i must admit mine never goes any where near my local town as normally i use my wifes mk3 golf 1.6, for doing the shopping run etc so my MPG is purely motor way and a little stop start traffic, and only running cold for about five mins at both ends of the daily journey.
Eventually i'll replace all relays, all fuses, sensors it's just a thing i do with older cars, usually rules out these as possiblilies if anything goes wrong
HairyScreech
i used to get about 32 on the 320 now getting about 36.
HairyScreech
getting 36 average over 300 miles mainly motorway? its a 325 now. hoping to get at least the same of better with my minty mint rebuild, as i wont have a 1/4 inch gap is my inlet gasket
the 320 was in good fettle but could have been better, still got around 32 with my light shoes on, square root of fark all with the throttle stomping boots on.
daveyboy20
Thats brilliant! I get between 19 and 23 mpg and its got low mileage and runs well! I cant really afford to run it to be honest, thought it'd get bout 30mpg!
I get Sixteen on a good run? what the hell?
i see 10 quite regularily.... if i drive it normally i get 25+
- murran
get low 20s all the time pretty much out of my 320i.
i remember the '85 audi 90 quattro i had last year, now that could drink fuel! did 7 laps round croft, used nearly half a tank!!!!!!! had to come in due to no brake pedal left!
e21 killing tyres with e30 325 powerzzz
drifting on the cheap......... www.trampdrift.com
e21zone........ www.bmwe21.net
