FUEL PROBLEM
MARK316I
Post Tue May 17, 2005 9:24 am
I GOT A 316I WITH A 318I AIR FLOW METRE ON IT. MY CAR DRINKS PETROL IS THIS THE PROBLEM? :)
Templ8e30
Post Tue May 17, 2005 2:34 pm
Could well be the problem mate, might also be the 2 short fuel hoses under the inlet manifold.
My missus 316i had this common problem, the rubber perishes with the heat off the engine and splits causing fuel to leak and crap mpg results !.
Hope this sorts it :D
Iain T
2007 Mazda 6 2.0 estate
Post Tue May 17, 2005 2:36 pm
i reckon its the airflow meter - think they are different 1.6 - 1.8
elliot
Post Tue May 17, 2005 7:44 pm
Templ8e30 wrote:Could well be the problem mate, might also be the 2 short fuel hoses under the inlet manifold.
Iain T
mine are starting to go. what size,in mm, are the pipes?
elliot
