COME ON, NEED SOME HELP HERE: chip for storkers
Guest
Post Thu Jan 20, 2005 10:03 am
I am intending of building a stroker using a 325e block an everything else from my actual 320i engine, but:
Do I need to change the chip on the Motronic 1.3 engine management?
If so, is there a chip available for this combination?
If I don't, what would be the asociated problems?
Guest
Post Fri Jan 21, 2005 8:35 am
Any one?
Ant
Retired Team Member
Retired Team Member
Post Fri Jan 21, 2005 8:38 am
Short answer is yes mate, the 2.0 chip will simply not give enough fuel, the advance will be out as well due to the longer throw crank.
you'll need a 325i intake and injectors too to getthe best outa the beast once complete
as for the chip, what ECU do you have dude ??
Guest
Post Fri Jan 21, 2005 8:48 am
Thanks a lot for your help, Ant.
My Actual ECU is Bosch Parts number 0.261.200.381
From your response I assume that my 320 head would be OK, but would need the 3.0 pressure injectors and fuel pressure regulator combination plus a throttle body from the 2.5 engine.
I am not just looking for top end hp, but a combination that is supposed to give about the hp output of a 325 but with much more lower RPMs torque.
