I've now got an ecu that I don't mind hacking apart for the motronic connector and was thinking about building the MS in to the old motronic case. Just removing the old board, snip the connecotr pins and solder in. Will get a better idea of if things will fit when the MS kit arrives but was wondering if anybody else has looked in to doing it this way?
Basically I can then switch MS in and out easily without bastardising the loom.
Motronic to Megasquirt Plug and Play Guide
