Cant get in my car!!!!!!!
clairebear
Post Thu Sep 20, 2007 9:33 pm
Hi, my second BMW, an E34, 91 Model...well...i cant get in it!! Its been sitting in my garage for a while and i need to get my 318is in there, is there a way i can open it with a flat battery???
Thanks in advance!!
Post Thu Sep 20, 2007 9:36 pm
Yes, you have to pull the driver's or passenger's door handle up and turn the key hard round (you may have to release and re-do it two or three times) but perservere and eventually it will open the door!
clairebear
Post Thu Sep 20, 2007 9:42 pm
Thank you xxx
Post Thu Sep 20, 2007 9:53 pm
No worries! Could also be worth a look at this http://www.bmwe34.net/e34main/trouble/Locked.htm
Good luck :)
whipsey
Post Thu Sep 20, 2007 10:12 pm
or if you want to get under neath get a spare battery and a set of jump leads attach the leads to the battery under the bonnet from underneath then down to the battery outside and turn the key in the door :D
gareth
Post Thu Sep 20, 2007 10:28 pm
whipsey wrote:or if you want to get under neath get a spare battery and a set of jump leads attach the leads to the battery under the bonnet from underneath then down to the battery outside and turn the key in the door :D
you'll be there a while, it's under the rear seat!!!! on a E34!
on my wifes one, when this exact thing happened, it took a little while fiddling but i think you have to open the drivers lock with the door handle open (or part open) it wasn't exactly like the guides but this may be due to wear or something. anyway, faffing with the lock and door handle combinations for a few mins will do it! :D
i have heard that unlocking the boot and connecting 12V across the boot light will do it but that's a bit unnecessary if the lock thing works!
whipsey
Post Thu Sep 20, 2007 10:32 pm
i had an e34 the battery was under the bonnet
:D Image
gareth
Post Thu Sep 20, 2007 10:33 pm
really? maybe it was just cos ours was a sport...
whipsey
Post Thu Sep 20, 2007 10:34 pm
maybe lol
doughboy
Post Thu Sep 20, 2007 10:59 pm
wow, with those rims you look like a drug dealer :?
SPADGE
Post Fri Sep 21, 2007 9:48 am
Gareth/Whipsey all the 535's 530's and some 525's have the battery under the rear seat. The rest have it in the usual place under the bonnet :wink:
bmwsport
Post Fri Sep 21, 2007 9:53 am
Yep i'm sure you just put the key in the lock and turn whilst lifting the handle up and down a few times, or pump it if you like. :cool:
whipsey
Post Fri Sep 21, 2007 2:54 pm
was a 520i hence the reason i got rid of it
